COPY CLIPBOARD FAILED
poe
Observer Observer
Message 1 of 10
poe
Observer
Observer
Suddenly in one of my drawings i can no longer copy and paste.  I get the copy clipboard failed error message.
I have looked through this forum with no real solution to the problem other than start over.  But that is not possible time wise due to the amount of layout tabs and layer control. Any help would be greatly appreciated.
Replies (9)
Message 2 of 10
Alfred.NESWADBA
in most cases this happens you have proxy objects inside your dwg-file.
Try to delete them (maybe using this tool >>>click<<<).
If that does not work then please upload your dwg-file + a screenshot after starting command _ABOUT so we can see your type and version of AutoCAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 10
poe
Observer
Observer
here is a copy of the drawing and screenshot.  Zombiekiller did not work
Message 4 of 10
pendean
Community Legend
Community Legend
You have to INSERT your problem file into a blank new file to make the problem go away here in plain AutoCAD2019.
Message 5 of 10
Alfred.NESWADBA
create a new drawing (make sure you have the same units set in the new file as in the existing one).
Use command _INSERT to insert the geometry from the defect dwg into the new drawing.
Use DesignCenter to import the layouts ... but test after each layout if the issue then arises again.
- alfred -
Alfred NESWADBA
Message 6 of 10
poe
Observer
Observer
I have done this once already today insert the bad drawing into a new .dwg.  Only to have the problem come back again. It is time consuming to set up each layout over again only for it to happen again.  What could be causing the issue?  When the problem started back i isolated one layer and tried to copy and paste the line work. "copy clip board failed".  when before i isolated the object it would copy and paste just fine i do not know if this information would help.
Message 7 of 10
Alfred.NESWADBA
No need to do this manually
You can use DesignCenter to import layouts from one dwg to the other.
- alfred -
Alfred NESWADBA
Message 8 of 10
rkmcswain
As @Alfred.NESWADBA said, proxy objects.
I've seen this here with multiple users using AutoCAD in an otherwise Civil 3D environment.
With the C3D Object Enabler installed, the copyclip problem goes away, but at a cost. When the OE is installed, AutoCAD becomes "aware" of the AEC objects and if those objects are numerous and/or complex, AutoCAD slows down to a crawl.
Try the applicable OE install first.
@poe
Message 9 of 10
pardeepsingh2807
Community Visitor
Community Visitor
Solution: Copy to Clipboard Failed Error in AutoCAD (Using Layout Copy Method)
I found a simple solution to fix the “Copy to Clipboard Failed” error in AutoCAD.
Steps:
1- Open the drawing file.
2- Go to the Layout tabs.
3- Select the All layouts.
4- Copy the selected layouts to create new layout copies.
5- After the new layouts are created, delete all the old/original layouts.
6- Save the drawing.
7- Now try using Copy (Ctrl + C) again.
it should now work without error.---   😊😊
Message 10 of 10
manieshkumar.suresh
Clean and Export the Drawing:
- Run AUDIT and -PURGE (option "R" for RegApps) to clean the file.
- Use EXPORTTOAUTOCAD or EXPORTC3DDRAWING (for Civil 3D) to export the drawing to AutoCAD DWG format.
- Alternatively, export the drawing using DXFOUT (AutoCAD R12 format), then reimport it using DXFIN in a blank drawing.
Check for any proxy objects in the drawing and try to delete it .
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
