EXPORTTOAUTOCAD or AECTOACAD these two commands repeat every one or two hour to solve copy object past as block (auto-generated)
Working with Xref file, After reference editing session an object remove from working set Refclose then copy object Ctrl+V its past as block.
After export to autocad new file Clean up WBLOCK, AUDIT, RECOVERALL again XATTACH Working with Xref file one or two hour it will be repeat Ctrl+V its past as block.
All XATTACH CAD file also Clean up separately WBLOCK, AUDIT, RECOVERALL
Version Using AutoCAD 2015
Thanks & Regards,
JAYHAR.M.J
Detailing Engineer
Solved by jayhar. Go to Solution.
Hi All,
its Solve....
1. I copy my drawings and past to new file.
2. Before attach xref i cleanup file some error found and fix, delete all unwanted drawings purge and save.
3. Then i attach xref in new file.
Always i am working in new file, this file is received from client, i have be seen some of hidden files of GA drawings, Schedules, IFC drawings etc...
I understand so many employees are work is same cad file, then i copy past drawings to new cad file.
Thanks & Regards,
JAYHAR.M.J
Detailing Engineer
CICON Rebar Solutions Pvt. Ltd.
DD Trade Tower, Kaloor-Kadavanthara Road,
Kaloor, Ernakulam, Kerala,India - 682017
E-mail : jayharcicon@gmail.com Mob : +91-9961032444
Hi @jayhar,
Looking at your drawing, it has geometry that is fairly scatter across the screen. Is it worth trying to move the details out of this plan file into their own file?
I ran Audit, PURGE, and -PU>Regapps to clean up the file and then also performed an exporttoautocad. The file is missing the xref's so I cannot perform the same cleanup steps but I suggest that you do that on your side.
I am not having any problems with copy/paste on my side but if you continue to see this can you try WBLOCKing to new files to see if that works?
