Copy an object on multiple UTM coordinates
Okay so here's my problem,
I created a SCR text document with multiple UTM coordinates. I added the word LINE. Then ran it through command as a SCRIPT. The points show up on the drawing but they are all connected to each other. I want them to be seperate points, so I created an X with 2 lines. Now, I want to copy it to all the coordinates in the text file. How do i do that?
thanks
Murph_Map
Instead of the line command you should of used the "point" command and set the point style "DDPTYPE" You can even use the "MULTIPLE" command to make it easier.
EX.
MULTIPLE
POINT
1,1,1
2,2,2
3,3,3
Murph
Supporting the troops daily.
thanks big time
