Copied viewports are not shown on print/pdf
dbuilder
Message 1 of 8
dbuilder
I used multiple viewports for construction notes. I copied the plan viewport and multipled it. They looks fine on CAD view but not printing on PDF/paper. All viewports are under a same non-plot layer.
Thank you for your advise!
Replies (7)
Message 2 of 8
ChicagoLooper
Is your titleblock in modelspace or on a layout tab? It looks as though it's in modelspace.
If that's true, you'd be better off putting your titleblock on a Layout Tab instead. Setup your sheet size using Page Setup Manager first then put all your viewports on the layout too. Each viewport can placed 'inside' your titleblock's border. From top to bottom, you VPs will be (1) your profile grid, (2) plan viewport, and (3) construction notes.
Chicagolooper
Message 3 of 8
dbuilder
Thanks for your reply! but no it's not in modelspace. I just use the dark background theme. the titleblock is XREF'ed on a Layout Tab, and every contents are located within the TB border.
Message 4 of 8
RSomppi
I think you mean that the content of the viewport is not printing. Check to make sure the layer(s) of those notes is(are) set to plot.
Message 5 of 8
dbuilder
Thanks you RSomppi, but I tried that and it shows only boundary lines...
Message 6 of 8
RSomppi
That would be the layer that the viewport is on.
I was referring to the layer that the notes are on.
Message 7 of 8
ChicagoLooper
@dbuilder wrote:
<.... I just use the dark background theme. the titleblock is XREF'ed on a Layout Tab, and every contents are located within the TB border....>>
Looks like Carpenteria, off the 101., correct?
Can you please upload a screenshot of your layout tab with all viewports visisble? I know your VP are set to No-Plot, but show them in your screenshot anyway so the VP arrangement can be seen.
Chicagolooper
Message 8 of 8
pendean
Community Legend
Community Legend
DWG file please.
