coordinates background turn off?
Message 1 of 10
Hey all, i set some contraindicates on a master plan yesterday but the contractor wants the coordinates background turned off. how do i do this?
Accepted solutions (4)
Replies (9)
Message 2 of 10
Alfred.NESWADBA
from the JPG it's hard to say what you have as objecttype. So I can only guess:
Try to turn off FIELDDISPLAY (>>>details<<<)
If I'm correct with that then please understand that this grey background is not printed, it's just as information on the display to know that are fields! If you print to PDF you won't see that background.
If that does not help then please upload the dwg-file so we can look into that.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 10
S.Faris
To turn off the background of fields
  1. On the command line, enter FieldDisplay
  2. When prompted for a new value, enter 0
Summary of the varuable
Value
Description
0
Fields are displayed with no background
1
Fields are displayed with a gray background
SALMANUL FARIS
Message 4 of 10
Actually i need to add a white mask that will be printed ?
Message 5 of 10
Alfred.NESWADBA
If you want to make the background (behind the text) invisible, then you might need a mask, yes.
If your question is how you do that I can only repeat ... without the dwg-file we don't know what you have (block with attributes, leader, mtext, ...?), if we know that we can give valid suggestions.
For MTEXT objects (and objects based on that like multiline attributes) you can select the object and activate the masking.
- alfred -
Alfred NESWADBA
Message 6 of 10
Yeah So the grey bit behond the numbers is grey and will not be printed but what i have been asked to do is to change the grey to a white that will be printed to show the cords to the contractor more easily
Message 7 of 10
Alfred.NESWADBA
In case these objects are FIELD's ... then yes, correct.
You are asking for "which tool do I need to open a part", but you don't show which type of screws you had used to close it. As long as we don't know which type of objects you have we can't describe which tool to use!
The suggestion with MTEXT did not work? Then please upload a dwg-file with at least one of these objects you want us to help you how to add a printable white background.
- alfred -
Alfred NESWADBA
Message 8 of 10
S.Faris
If you are using a attribute inorder to graphically represent the coordinates in your drawing, You have only 2 choice
  1. Grey Color (FIELDDISPLAY-1)
  2. No Background (FIELDDISPLAY-0)
On the other hand if you are using a text inside a dynamic block, there is a workaround to achieve what you need
  •  turn off the field display (FIELDDISPLAY-0) and use background mask from the properties of text
  • but in this case the coordinates are pulled from an object which is already inside the blockeditor, so it is tricky to make it work in the drawing space. I've made a sample file of what you are asking for(attached).
Try to edit that and learn for yourself what is happening inside the block and why.(But feel free to ask any doubt, if you lost 🙂 )
SALMANUL FARIS
Message 9 of 10
I've accepted your solution based on the effort you put in but i ended up  getting in trouble for downloading your file to the works hard drive,  never mind than you have a great day.
Message 10 of 10
S.Faris
The file I uploaded was just for you to get an idea of how it can be done. It was never meant to be used in another file.
You too have a great day 👍
SALMANUL FARIS
