AutoCAD Forum
Coordinates and label to excel sheet
1 REPLY 1
349 Views, 1 Reply
Hey guys. Can someone show me in the video how i can extract the information in the DWG and export it to DWG?
For instance i want an excel sheet with:
Vx.1 - length=2920mm x=15720 y=15710
Vx.2 - length=3240mm x=15300 y=11350
etc etc for all my walls.
is this possible? Or can i do it in another way?
Thanks in Advance
1 REPLY 1
coffeejeanpaul
I would make a table, use field select the object. Then choose Contents. After I added all the information I need. I would export the table to csv. Open the csv and save it to excel format is is lengthy method, but if you adjust any of the fields your table would update after a quick regen and you can export it information again.
Hope it can help.
Technology Administrators
