Converting STEP files to DWG pogramatically (C#)
Message 1 of 11
I'm trying to import a STEP (.stp) into AutoCAD 2016 and save it as DWG, which works as a user.
The main problem is about emulating the "import" command.
I didn't find any way to import in managed code, so I tried interop:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
using System;
using System.Collections.Generic;
using System.Drawing;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.Interop;
using AcadInterop = Autodesk.AutoCAD.Interop.AcadApplication;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Geometry;
[CommandMethod("steptodwg", (CommandFlags.Modal | CommandFlags.Session))]
public void Convert()
try
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
AcadDocument comDoc = (Autodesk.AutoCAD.Interop.AcadDocument)doc.GetAcadDocument();
double myScale = 1;
double[] ptArray = { 1, 1, 0 };
comDoc.Import(@"C:\test.stp", (object)ptArray, myScale);
The message is "Invalid argument".
I suppose the argument causing problems is the point of insertion, but I can't say for sure.
Replies (10)
Message 2 of 11
ampster40
sorry I cannot assist with the code, just providing the simple fact that AutoCAD by itself cannot work with step files. If you want to work with step files in Acad, you will also need to have AutoCAD Mechanical installed. Perhaps the code you're working on will need to be modified to work in conjunction with Acad Mech. HTH
Message 3 of 11
ampster40
also, instead of working with the "import" command, try utilizing the "stepin" command.
Message 4 of 11
Thanks for your answers, i didn't know about mechanical, but i don't have it and it works (as a user).
I don't have access to the "stepin" command"n what does it do? Is it only in mechanical?
Message 5 of 11
JDMather
@ampster40 wrote:
.... the simple fact that AutoCAD by itself cannot work with step files. If you want to work with step files in Acad, you will also need to have AutoCAD Mechanical installed.
Incorrect information.
Vanilla AutoCAD has been able to import STEP files for at least a couple of releases now.
Message 6 of 11
Patchy
Can it be done? Read this from Autodesk
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCA...
Look at where it said STEP.
Message 7 of 11
@ampster40 wrote:
sorry I cannot assist with the code, just providing the simple fact that AutoCAD by itself cannot work with step files. If you want to work with step files inAcad, you will also need to have AutoCAD Mechanical installed. Perhaps the code you're working on will need to be modified to work in conjunction withAcadMech.HTH
This is so wrong.....You can import step files with vanilla AutoCAD.
Message 8 of 11
ampster40
Tks JD, you are correct. It only handles 1/2 of the step file situation. It cannot export but it can import. Sorry for the bad info.
Message 9 of 11
As I said in the 1st post, I could do it as a user, so that's not the problem at all.
No offense, but I'm looking for developper's advices here.
Thanks for your answers anyway.
Message 10 of 11
Patchy
Then you need to go to proper group, not autocad users group.
Dig in here:
http://forums.autodesk.com/t5/custom/page/page-id/Discussions-Page
Message 11 of 11
Maybe look in the proper forum....
http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
