08:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I'm having trouble trying to turn a number of SPLINES and ARCS into a solid. I have looked extensively and have yet to find a solution that works. I have tried:
- Using the 'SURFNETWORK' command to create surfaces which I could then convert to solids, but this doesn't appear to work in circumstances where there are only three lines. I have tried breaking some of the curves in such a way that I would have 4 lines (2 in each direction) but for some reason this only works for particular parts of the model, despite what appears to be similar geometry (see attached image).
- Using the 'CONVTOSOLID' command and turning all the curves into closed polylines.
- Using the 'LOFT' command.
I've run out of ideas and I would really appreciate any help. I have attached the file and an image of the location where SURFNETWORK fails. Apologies if I'm making an obvious mistake here but I cant figure this out.
Thanks for reading.
