Converting dwg to stl
Message 1 of 9
I am trying to convert a 3D object I drew in AutoCAD 2016 from dwg to stl. I tried exporting but when I select the object and hit enter it removes the object from selection. Any ideas on what I need to do. I have attached the drawing.
Replies (8)
Message 2 of 9
Patchy
It's not a solid, if it's a solid then STLOUT.
Message 3 of 9
How would I make this a solid?
Message 4 of 9
Patchy
PEDIT, Join the lines, REVOLVE and use the line as pivot for 360 degrees; after that STLOUT.
Message 5 of 9
FeeopEngr
Since I only have access to Autocad Lt, I'll try on the fly. It looks like you have a group of surfaces. Try joining your lines (those in the lower left corner of your posted dwg) into a polyline or 3D poly and then revolve them. It should make a solid.
Feeop
Message 6 of 9
john.vellek
Hi minsonc,
I agree with @Patchy. In order to get this to STLOUT you will need to crate this as a solid. I tried to convert your surfaces but had no success as it does not appear "watertight".  I took your cylinder shape and created a circle and then offset it .5 to get the outer circle. I then used press-pull to pull it to the correct length. This object is a solid and allowed me to STLOUT.
I hope this helps.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 7 of 9
I used PEDIT to join the lines before I used REVOLVE here is the new object it still would not work.
Message 8 of 9
Patchy
Because you pline is not closed.
Message 9 of 9
Ok I got it to work after fixing that. Thanks for the help Patchy.
