Converting 3D Block to 2D
Message 1 of 9
I found the following block (please see attached URL), however it is in 3D and I need it in 2D for a plant layout I am working on. Is there a way to convert it to 2D? Does anyone also know a good website where I can find blocks for a plant and warehouse.
Thanks!! I appreciate all your feedback and help.
Replies (8)
Message 2 of 9
Alfred.NESWADBA
No URL here....
If you need it 2D in model-space you might try command _FLATTEN or command _SECTIONPLANETOBLOCK, if it's ok in the layout (depending on your AutoCAD release) you might try command _VIEWBASE
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
injineri
FLATSHOT working for me
Message 4 of 9
I tried the flatten company, however when I copy and paste it, the block is still in 3D. I have attached a picture, I am trying to only copy the top view of the block.
Message 5 of 9
Alfred.NESWADBA
_FLATTEN was not the only suggestion 😉
(whereas I don't know if _VIEWBASE is working on Mac-AutoCAD, maybe it's better then to ask in the AutoCAD for Mac forum >>>there<<<)
I can see a picture (that are just pixels), but that does not give me the option to see which geometry objects are used to build that component.
A dwg-file would give us more info's about your object.
- alfred -
Alfred NESWADBA
Message 6 of 9
Thanks, it worked.
Message 7 of 9
AVCPlugins
You may find it convenient to use the FLT command from the AVC_Flat plugin. This command sets fewer questions than _FLATSHOT and flattenes more than one different object (polyface meshes, 2d/3d polylines...)
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
Message 8 of 9
I have similar question and flatshot worked for me.  My issue now is how do i get rid of all those lines once it is convert into 2d.  I tried convtosurface but the lines are not going away.  Anyone can help me with this?  Many thanks.
Message 9 of 9
Alfred.NESWADBA
Which software do you use? Because it's telling me the DWG-file is not created by an Autodesk product, but we need to know what product (and version) you are using to give you valid suggestions ...
[EDIT] PLUS: I guess it will be difficult to get a clean 2D model from something like that ...
[/EDIT]
- alfred -
Alfred NESWADBA
