AutoCAD Forum
Converted My drawing from ft to inch and when drawing a line I still get inches
10 REPLIES 10
Message 1 of 11
1380 Views, 10 Replies
Hello there!
I appreciate any input on this. Here is my question:
My drawing was in inches and I used -DWGUNITS to converted to feet. An object that had a dimension of 72" after the conversion to feet now shows a dimension of 6 (72"=6'). The problem is that the dimension of six is actually 6" not 6' that I want. I've done previous conversion and haven't had this issue.  Please let me know what am I doing wrong?
A
10 REPLIES 10
Message 2 of 11
imadHabash
i think that there is a conflict between your post headline and the content !!!
to get 6" - as i understand - i suggest to change your dimension style unit format to Engineering ( see below image )
Imad Habash
Message 3 of 11
in reply to: imadHabash
@imadHabash Thank's for your answer. I already did that, when I draw a dimension it gives me the dimension in feet just like I  want it to be set up, but when I measure/draw a line, it only draws it in inches not in feet.
Message 4 of 11
pendean
Post your DWG file, let us see what other settings there are that may have been missed too, like your DIMSTYLE settings.
Message 5 of 11
in reply to: pendean
@pendean Please see attached doc.
Message 6 of 11
pendean
Your DIMSTYLE is set to multiply all results by 12:
Your DIMSTYLE is also not set correctly for text size: are you manually fixing each dimension after placement?
Message 7 of 11
@pendean that is correct. That's the only way that it can reflect the correct dimension, when I set up to factor 1 it gives me the dimension to inches. I converted this drawing from inches to ft and its not reflecting that correctly. why?
Message 8 of 11
pendean
-DWGUNITS has absolutely nothing to do with DIMSTYLE settings.
See attached and below, this is how you set it for feet: and remember, your unit is always a foot.
Message 9 of 11
Kent1Cooper
You have it set up for Architectural Units, in which a drawing unit is an inch, despite your -DWGUNITS setting [which, as I understand it, has more to do with the drawing's relationship to other drawings  than internal conditions, but it's not in my vanilla AutoCAD -- only in overlay programs].  The same is true for Engineering Units.  If you want a drawing unit to be a foot, you have to use Decimal Units.  Civil Engineers do this all the time, and they define their Dimension Styles to add a foot mark as a suffix.  The drawback is that your [for example] 2'-6" dimension will come out as 2.5'.  I'm not sure there's any way around that.
Kent Cooper, AIA
Message 10 of 11
@pendean thank you! for the first screen shot (I'm clear).
For the second one if I try to enter a dimension in feet and inches I get a red box, so I need to have it in engineering or architectural type length.
When I made the change and draw a line of 6' its way off in comparison to the actual 6 feet object in the drawing. When I measure the line that I draw at 6' (in yellow)  and I add a dimension I actually get 75' instead of the 6' that I draw.
Thanks!
Message 11 of 11
pendean
With AutoCAD, you cannot have dimensions in ARCH or ENG (inches) if your DWG file is feet. You have to decide which way is more important.
How did you dimension the line your drew? Are you forgetting your DWG file is now in feet, so 1-unit=1-foot? See attached white line next to your bench, it is 6-feet long drawn by entering only 6 when asking for length.
AutoCAD Inside the Factory
