Converted Drawing from MM to Inches
I have a drawing that was drawn in MM, I re scaled the drawing by a scale factor of .03937, when I check the dimensions it appears that it is still off by around 5"
Anyone ever experienced this before
pendean
Community Legend
Community Legend
1mm=0.03936996inch
You are close enough that 5" (1237mm)  just means the wrong MM dimension was used for the object you are measuring perhaps: what bare you measuring, and where?
I drew a line and re scaled the drawing, it was a PDF file convertered to a DXF and it was off by 5 ", so I just Re scaled the drawing and it came out perfect, small learning curve
John Maier
