I having issues when converting to pdf my raster image don't show in the
new created PDF files. If I attached the same image it will convert the image fine
I have tried several options but, I can't seem to find a solution
See image attached
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Please describe your process from AutoCAD drawing to Adobe PDF. For instance, how are you producing the PDF from AutoCAD? It appears that you are using Adobe PDF to do this which is not a native AutoCAD feature. Is there a reason you don't use the built-in driver to create the PDF?
You are welcome to also attach some sample files for me to work with on my computer so that I might be understand your issue.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
