Convert Solid to Polygon Mesh?
betsy.kirtland
betsy.kirtland
Hi all, I am working on a finite element model of a concrete structure, and I'd like to develop the mesh for the model in AutoCAD and then import it into my FEA software. I have a 3D Solid (see attached) that I'd like to convert into a group of Polygon Meshes, as Polygon Meshes are the element type needed to import into my FEA software. I can model half of my shape within my FEA software (and export it to AutoCAD - see attached), but unfortunately I can't model the entire thing due to program limitations. Any help or advice anyone can provide would be greatly appreciated!
AVCPlugins
Try experimenting with the _CONVTOMESH command
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
betsy.kirtland
Hi @AVCPlugins , unfortunately I don't think this converts objects to Polygon Meshes; it converts them to standard meshes. The FEA software that I am using reads standard meshes as shell objects, and polygon meshes as solid objects, and I need to model my concrete as a solid object. Therefore, it has to be polygon meshes.
AVCPlugins
I could create a similar conversion program. but not free. Maybe someone will create a free script for you.
Plugins for AutoCAD
A>V>C>
betsy.kirtland
Understood, @AVCPlugins, thanks. I don't have budget to pay for someone to create a script.
Alternatively, do you understand how to use the "3Dmesh" command? That command creates polygon meshes manually, and since my shape is relatively simple, I could draw them myself (begrudingly), but the command is very confusing to me and I'm having trouble just drawing a rectangular prism.
