My selected object highligh effect is lost, how do I get it back
I have this problem with Autocad 2023. Autocad version 2021 is fine, I uninstalled and reinstalled autocad 2023 but the problem is still not resolved
i want it like this:
[ The subject line of this post has been edited for clarity by @handjonathan Original: Highlight when selecting objects ]
Solved by daohaquang. Go to Solution.
Set your HIGHLIGHT System Variable to 1
Source:
Best,
~DD
It's just choosing between 2 effects: Dashed lines & glowing line highlighting effect
You should just use a Reset to default tool instead of reinstalling.
So you never had that in 2023? In that case it's a graphics issue. Make sure have the latest GPU driver.
see if you can go back to the previous intel GPU driver before the update
very good...glad you got this resolved.
