Convert solid to a polyface Mesh (legacy AutoCAD)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Our customer needs to convert a 3D solid into a 3D polygon mesh, which as I understand is a legacy from older versions. We are able to create meshes from solids using the CONVTOMESH command, but these are 2D planar meshes, not 3D solid mesh. We are able to draw solid 3D polygon mesh (using the PFACE command), but this requires specifying every vertex and face, which is impractical and does not solve our problem. Ideally, we want to convert an existing solid, not create new ones. Less ideal, but still workable, would be an easier method for creating these 3D elements.
Please note that Mesh and Polyface mesh are not the same thing.
They are using SAP 2000 and this requires certain paramaters. Has anyone had to do this and have a workflow they use?
Thank you,
Nicole Morris
KETIV Technologies, Inc.
