Convert points to polyline
Good morning,
Is there anybody that can advise if it's posible to convert points to a polyline?
I have a scan of a component created by an OGP measuring machine which will only output quickly as points but to use it I need to to be a polyline.
Is there a quick way of changing the points or is it a case of joining by inputting manual lines from point to point?
Thanks for your help.
Lee
skintsubby
Have you tried using Map or Civil3D?
I'm assuming your co-ords are in CSV format (or similar)?
Does this help? --> http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-draw-polyline-from-xls-csv-or...
Also try in the customisation forum --> http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Mark
