convert multiple files from .dxf to .dwg format
Message 1 of 8
Hi, I'm using AutoCAD 2015 i have 500 .dxf files i want to convert them into .dwg format i know the command dxfout to convert them but this command works for each drawing. I want to convert all 500 files at a time is there any command or any script to run. If yes please explain me how to do
Thanks in advance.
Replies (7)
Message 2 of 8
john.vellek
Hi @Anonymous,
I checked in the Autodesk App Store and there is a free tool there that might help you do the DXF to DWG conversion called DXF2DWG.  Please let me know how well this works for you.
John Vellek
Message 3 of 8
is it possible to convert all the 500 files at single time or do i need to break them into some amount of sheets ?
Message 4 of 8
john.vellek
HI @Anonymous,
If this were me, I would test first on one or two of the DXF files.  If successful then considering doing perhaps 20-30 at a time. If that seems to work, then again increase the quantity.
I would also make sure that I have backups of all the data before running the conversion.
John Vellek
Message 5 of 8
When will we have the DXF2DWG version for the AUTOCAD 2019 available?
Message 6 of 8
john.vellek
Hi @Anonymous,
Since this is not an Autodesk product I don't have mush to say.  I have contacted the developer's support site to see if they can tell me if they plan a new version and if so, when it might be available.  Typically this takes a couple of days to come back to me but i will post when I get some information.
John Vellek
Message 7 of 8
john.vellek
Hi @Anonymous,
The developer was quick to respond and they indicate that 2019 support should be released by the end of June.
John Vellek
Message 8 of 8
Thank you very much!
