AutoCAD display colors Issue.
carlos.h.silva
Message 1 of 13
carlos.h.silva
Good afternoon,
I replace my old computer by new one (the new one with graphic Card NVIDIA GFORCE GTX 1050, last driver) I use a Samsung HDTV P2770HD.
I start with my AutoCAD 2018 and I found the colors very strange (you can see attached image).
For example the green color horizontal lines is ok, vertical lines the same green color looks white, the same for red colors look like pink.
The HDMI cable is the same, the monitor is the same as the old computer.
Can be a windows configuration?
Can be a problem in the graphic card?
Can anyone help me please?
Thank you so much.
Regards for all.
Carlos Silva
Replies (12)
Message 2 of 13
imadHabash
Hi and Welcome to AutoCAD Forum,
I suggest to disable hardware acceleration from 3DCONFIG command.
Imad Habash
Message 3 of 13
carlos.h.silva
Hello, good afternoon,
thank you so much for your reply,
I just turn off the option hardware acceleration but the problem persists
Message 4 of 13
imadHabash
would you please try to restart your AutoCAD .
Imad Habash
Message 5 of 13
carlos.h.silva
Thank you so much once again for your help.
I did a restart of my autocad and I have the same problem.
Can be a windows configuration or a problem in the graphic card?
Message 6 of 13
imadHabash
>> Can be a windows configuration or a problem in the graphic card? <<
exactly ... this is the next step is to make sure that we have a proper graphic card .
all the best...
Imad Habash
Message 7 of 13
carlos.h.silva
attached you can see an image from my outlook,
I have a cyan circle with AC letters and around this circle I have a black outline.
Message 8 of 13
imadHabash
would you review your attachment please ?
Imad Habash
Message 9 of 13
Todd_Rogers
I use that same video card, and I have the same problem. It's the video card. It's a gaming video card. One thing you can change is, go to NVIDIA Control Panel, click Manage 3D Settings, select Program Settings tab on the right, and make sure AutoCAD is being used with that particular video card. Sometimes it will be set to the Intel HD video card.
Todd Rogers
Civil Administration at Walter P Moore
Message 10 of 13
carlos.h.silva
Thank you so much TRogers for your help.
Do you have the same problem or do you already have the problem solved?
There is no solution?
Message 11 of 13
Todd_Rogers
It's just the nature of the video card. I love mine, but I just ignore the color differential.
Todd Rogers
Message 12 of 13
carlos.h.silva
Have you similar problems in Microsoft software?
did you see my last attachment (image from outlook)?
Message 13 of 13
Todd_Rogers
I do.
Todd Rogers
