convert multiple drawing sheets into individual drawings sheets file
Hi
I have one AutoCAD drawing file in that 500 sheets are there can you please help me how to convert 500 sheets into single drawing like individual sheets Autocad.dwg files.
Please help with solution friends, thanks in advance
imadHabash
as i understand ... if your sheets are in layout tabs ... right click on your layout tab then select Export Layout to Model .
Imad Habash
Hi imadHabash
No, All sheets are in Model .please check the below attached image for your reference.
maratovich
No problems.
Use it - Revers
Give an example of your .dwg file, I will do a lesson for you.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
