Is there a way to convert shapes, solids, surfaces, polylines, etc... to a 3D Solid?
Be it using AutoCAD or a 3rd party utility?
Tony
there exist some tools to convert one 3D object to another type, but how should a 2d-object lile polyline or solid or shape be converted to a 3D-Solid?
Can you describe what is the workflow you want to go, when do you need/would you use such conversions?
- alfred -
Yes (what is your definition of "shapes"), Yes, Yes, No (at least not without a "lot" of user input).
Can you attach your file here.
Hi, JDMather,
just out of curiosity, how do you (automatically) convert a SOLID to a 3D-SOLID? (sample of a SOLID-object attached).
- alfred -
I don't deal with "imaginary" parts.
Can you post something "real"?
I gave you a real drawing (DWG file) and within that the real geometry object of type "SOLID" (the only geometry type that is handled as "SOLID" in AutoCAD 😉
I'm wondering about that "yes","yes", ... not only for SOLID, also for SURFACE (as this can't be converted when it is not watertight), I don't see that as easy as you do .... and that's why I try to learn how you do that.
- alfre d-
Tony
It is difficult to convert 2D objects to 3D objects. If you are looking for one command for each of these to convert them to a 3D object you can try
convtosurface or convtosolid
Keep in mind they won't convert everything. For example, convtosolid won't work on a 2D solid but it convtosurface will. Once it's a surface you can use other 3D commands and tools on it.
Closed polylines, polygons, boundaries, etc. can be extruded which converts them to 3D objects. A nonclosed polyline can't be converted. you can use it as a path for the sweep command and similar tools.
