Convert JPG to STL in AutoCAD
Hello guys,
I'm looking for a way to convert either a .png or .jpeg file to the file types .stp and .stl Is there a free way to do this for at least 4 files?
Thank you for any guidance! -Alex
@Anonymous,
john.vellek has edited your subject line for clarity:How to convert files
swieciakpawel
Hello alxdott,
The problem you described isn't just a matter of conversion.
The .jpeg and .png are raster formats and you wish to export data that is exclusive to vector graphics. If that would be a 2D object, You'd have to either re-draw the objects or trace them using any available "Raster to Vector" tool.
But considering you want to obtain an .stl / .stp file I assume, that this would be a 3D object for 3D printing. Therefore it's important to note, that If the object you have in .jpeg format is 3D object, then you cannot retrieve such data by any means other than drawing this object using any vector graphic software.
If you draw the object in AutoCAD, the conversion is pretty simple. You just use the EXPORT command and choose the *.stl extension as your desired export file extension.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Did you understand the explanation posted by @swieciakpawel?  It is sound.  To get this date into a 3D format you are going to need some vector information.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if you still need help on this issue. Have you tried creating vector information from your image file(s)?
John Vellek
pendean
Community Legend
Community Legend
You want to convert a static 2d picture into a 3d object? What movie did that come from 🙂
Sorry my friend, this world isn't that advanced yet, not with one single picture especially.
Hi, you can use websites like:
http://www.embossify.com/ - jpg to stl, but only black and white images work well, i would also recomend useing simple shapes.
https://www.selva3d.com/ jpg to stl, but only black and white images work well, i would also recomend useing simple shapes.
(png can be converted to jpg with microsoft paint even).
Simplify3D has such a feature.  It can take a .jpg file and convert it into an .stl.
