Convert Imperial Template to Metric
Hi all,
I actually use AutoCAD LT the majority of the time because we send out only 2D drawings anyway and it suits my needs without the added potential errors of having a separate dimension. Im sure the method for both AutoCAD and AutoCAD LT will be the same for this. Anway...
I have created over the years my perfect template with imperial units. More and more I am coming across metric requirements so I decided to make a copy of my template and change the necessary components to metric. This was not as easy as I thought. I changed the "units" to mm, and changed my primary units in my annotative dimension style to mm.
I was annoyed to see that when I drew a 200mm line, and tried to plot it at a 1:1 scale on my 8.5x11 paper, it was huge as if it assumed the line was 200 inches.
Any other threads I have read on this basically just say to change everything with a scale of 25.4. This method does not work for my paperspace scale. I want to type in 200 and have it show up properly.
Sandro
kennyj
Hello Bnwtech,
In your Layout Space, right click on the tab.
Under Page Setup Manager, change the plot scale units from inch to mm.  Then set it back to 1:1.
This should take care of the views for you.
Hope this helps!
Kenny
Emmsleys
Thanks for sharing that helpful tip! @kennyj
Sarah Emmsley
Technical Support Specialist
