Convert contour polylines into triangular mesh
richard.tam
Observer Observer
richard.tam
Observer
Observer
I am trying to build a 3d model for CFD, and I am having problem converting the contour lines into a 3d triangular mesh.
Alfred.NESWADBA
best would be to use Civil 3D for that, do you have access to Autodesk Civil 3D?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
richard.tam
Observer
Observer
Sadly I don't.
Alfred.NESWADBA
does the attached file help?
- alfred -
Alfred NESWADBA
richard.tam
Observer
Observer
It looks very similar to the end product I want, however the edges are a little bit janky, also the ground level completely changed. I think I will have to loft the contour lines manually to stitch the mountain out
