Conversion problems, help needed
​Hello,
I'm trying to convert a .DWG file containing height information from measuring elevation in the form of a point cloud, to a format like .OBJ or .3DS. The file's been created professionally from a Leica land measurement device, and contains less than 200 points.
I'm attaching the file. Anyone that can help me with this conversion?
Side information: I've got a FME license but have a problem with text strings containing Swedish letters "åäöÅÄÖ", that generates an error when trying to write the file that seems to expect none such letters.
Thank you /Peter
Alfred.NESWADBA
OBJ files need surfaces or volumes, points are not enough to work with.
Also for FME you first need at least surfaces (and use it with a thickness) or you need volumes.
Just to have points is not a valid information for FME systems.
You might use Civil 3D to get surfaces from points (but then you'll also need break lines to have a better match to the real land surface). Also there, just points does not automatically create correct meshing.
Have you got any more informations/data from your surveyor?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Hello Alfred,
Thank you for the reply. I'm an engineer, but a complete beginner at CAD. I'll use this information to build my house on a very irregular plot.
The file from the map engineer is a bonus; they usually don't do this, but I got more measurements just because they were kind, but left me the file as-is for me to handle.
Is there any chance you could help me with taking the information over to something like .DAE, 3DS, FBX, PLY or OBJ? I have Blender that can read many formats, but not .DWG.
I realise you'd need to convert into surfaces. I hope this is will not mean a lot of work; I'd be very grateful for some help getting those points or surfaces over to something Blender can read.
Thanks /Peter
Alfred.NESWADBA
Then look to that DXF-file, Blender can read DXF. I saved your points to DXF format 2007.
But points can't be saved to formats like OBJ or FBX as points are no renderable objects.
- alfred -
Alfred NESWADBA
Thanks Alfred,
I've enabled DXF import in Blender, so I finally have a point cloud there. Now looking into converting it into surfaces in Blender.
Thanks!
