conversion from 2018 autocad file to 2014 file
monazg
Observer Observer
monazg
Observer
Observer
Please can anyone help me convert my 2018 autocad file to a 2014 drawing?
Thanks in advance.
Tomislav.Golubovic
Do a SAVEAS and then select 2013 as the filetype
cadffm
And without Autocad 2018+
Install DWG Trueview,
use the DWG Convert Tool
Sebastian
Grover_Puma
es buena la recomendacion de @cadffm
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Hi, you can open options in Autocad, switch to the Open and Save tab and select the format in which you actually want to save a drawing.
You can see it in the picture.
