AutoCAD Forum
Conversion factor from meter to feet.
4 REPLIES 4
18588 Views, 4 Replies
I would like to change the conversion factor  of  meters to feet to a more accurate value rather that 0.3048. In my place we use the meter to feet conversion with 3.2808333. It makes a lot difference when the decimals does not carry up to 7 decimal place.
Anybody out there who can help me? Thank you!
4 REPLIES 4
h_s_walker
Click on Format
Click on Units.
You can change the viewed precision there.
Howard Walker
Left Handed and Proud
jggerth
converting where?  in QuickCalc?  using CAL command?  or INSERT or XREF ?
RockyBrown4134
Where are you trying to make the conversion? Are you trying to set up a dimension style with alternate units?
For information, the multiplier to convert feet into meters is 0.3048. The multiplier to convert meters into feet is 3.281 (3.2808333 your precision).
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
The Warsaw convention of 1959 agreed to the legal conversion factor of 0.3048 meters in one foot. If you are looking for a more accurate conversion factor you are looking for something that does not exist.
AutoCAD Inside the Factory
