Is it possible to constrain an end point of a line to lay on another line? I need the end point of the horizontal dashed line to remain on the vertical solid line that it is currently laying on, but be able to move in the Y direction.
Solved by GrantsPirate. Go to Solution.
Hi and Welcome to AutoCAD Forum,
how about turning ON ortho mode ( F8 ) for vertical and horizontal moving directions .
Imad Habash
You can use the Coincident constraint, pick the endpoint of the horizontal line, then use the Object option and select the vertical line. You may have to at least add a constraint to the vertical line for Vertical depending on your needs.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
