Complex Linetypes
Complex Linetypes
andy.clegg
Complex Linetypes
andy.clegg
I need to create two complex line types without the use of shape files, please see attached.  Any guidance would be appreciated.
Valentin_CAD
@andy.clegg ,
Consider using WINGDING fonts. Check out the attached PDF pg.12 onward.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
@andy.clegg wrote:
... without the use of shape files, ....
Is there some reason that shape files are not wanted?  What makes the use of them any "worse" than the use of an embedded text element [which is your only other option]?
Kent Cooper, AIA
