Comparing paperspace tabs in one window?
david_ballinger
david_ballinger
I know in Autocad you can go under VIEW and Tile Horizontally or Vertically to compare two open drawing files at one time.  We can also use Viewports in Model Space to view two areas of the same drawing file.
Why is there no functionality so we can Compare two Paperspace Layouts in the same drawing file??
paullimapa
No such feature.  But you can always open a 2nd session of autocad and open that same dwg looking at another layout to compare.  The drawback is you can only make changes on the first session & not the second
Paul Li
IT Specialist
@The Office
david_ballinger
Need this to be added in a future release.
paullimapa
Autodesk feedback page is here:
Product feedback (autodesk.com)
Paul Li
IT Specialist
@The Office
Valentin_CAD
@david_ballinger ,
In addition to @paullimapa  suggestion, you can also submit your Wish here:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
