AutoCAD Forum
Command text sizes
2 REPLIES 2
288 Views, 2 Replies
Command text sizes
Hi everyone !
Fist sorry about my English... I'm french !
I'm having a problem with my new PC and autocad
DELL Windows 10, I7, 16 Go, x64, 3840x2160
When I work with autocad I have this :
I tried different versions (from 2013 to the last one), I tried an amtlib (worked for the top command line, but not for the bottom or the left), and I even changed my screen resolution to 1280x800, but Nothing worked !
Did some of you have the same problem ?
How did you resolve it ?
Thank you and have a great week-end !
Command text sizes
Hi everyone !
2 REPLIES 2
patrick.emin
patrick.emin
Hi, you have a french forum here: https://forums.autodesk.com/t5/autocad-francais/bd-p/127
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Alfred.NESWADBA
Alfred.NESWADBA
if you have AutoCAD 2017 install the Update 1 (please don't mix it up with "Service Pack 1", that is something different.
You'll find the Update 1 when you start Autodesk Desktop App, make sure you are logged in and wait a bit (can be hours) until the next search for updates is done. You should then get a message that update(s) are available.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
