Command - Reference Offset Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello: I am having an issue with the offset command. When I offset a distance in reference to a certain distance between two lines, it creates an astronomical offset distance. For example, using COMMAND OFFSET, reference distance between two lines that are a distance apart of 1/2", and select a line to offset, the line is offset to 850' - 5-1/16". Has this happened to anyone else and if so, what have you done to combat this issue?
I've tried transferring all the geometry into a file that is working properly with the offset command and it seems to transfer the issue over as well.
Thanks!
