COMMAND LINE SRINKS
cb94030
COMMAND LINE SRINKS
cb94030
I set the command line to the width of the screen, then little by little start shrinking. See attachments.After.PNGBefore.PNG
How do I fix this situation?
Thank you.
ennujozlagam
check here.
imadHabash
Click here to learn how to dock,anchor and float command window .
Imad Habash
pendean
Community Legend
Community Legend
May I ask why you need it to be so wide? The text in the commandline there is never that wide, all you get is dead gray space.
If this is just a need to look more organized, then just dock the commandline instead https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
cb94030
Thank you. So far it's working!!!!
cb94030
As you said, ideally would be to have the command line occupying 1/4 of the screen width, but when it starts shrinking little by little, it goes so small that it is useless.
