hello,
I have some problems with the Dim command.
when I type dim, I can't click anywere to measure something and it doesn't show any snapping symbols.
the command line says: 'Dim Dim', but i remember it saying something like 'Dim: define the first point' or something like that?
also my cursor doesn't show the question mark after i typed the command as it normaly would.
Thank you for helping me out
Simon
yes, the Dist command solved my problem.
We had been working on a school project for 2 days and i was a bit tired I guess 🙂
Try the command " dimlin " for linear dimensions
and " dimang " for angular dimension...instead using the command " dim"
this should work! 🙂
