AutoCAD Forum
Command: attin - bad argument type: lentityp nil
3 REPLIES 3
acejuniot
414 Views, 3 Replies
Hello everyone, I have a problem with the ATTIN command. I can still output the file with the ".txt" extension using ATTOUT, but when using ATTIN to import, I get the following message:
Command: attin
0 Block inserts modified.
I tried exporting, not editing the .txt file and importing it again but it still didn't work.
Thanks in advance!
3 REPLIES 3
cadffm
in reply to: acejuniot
Import to the same file you exported (and not edited) before?
Share a sample, create a .dwg with one block, save, use attout, use attin, still the same error?
Then share your .dwg and .txt file and we are able to finde the issue.
Sebastian
acejuniot
in reply to: cadffm
I think the problem in my drawing because when I copy it to a new drawing, it can be imported again. I sent you the file, can you find where the error is?
Thank you very much
cadffm
there was a change between attout and attin, but we can't say what you did.
Any change in your Blockdefinition (BEDIT/REFEDIT),
or it isn't the file you exported from,
or you changed one dynamic parameter value for all - like  Flipstate or position1x/y
It will work with your original .dwg too, try it again!
Open the file you attached, attout, attin, done.
Sebastian
AutoCAD Inside the Factory
