Command appearing in other drawing
When Im writting a command in the commandline it doesnt appear. Instead the command appears in other drawings that I have open.
It doesnt matter which drawing i try to execute commands in, it will always appear in other drawings. Im soooo frustrated about this problem. I dont understand how a bug like this can happen in a software with such a huge pricetag.
pendean
Community Legend
Community Legend
Is the AutoCAD program window maximized?
Are the DWG files maximized as well? Are you sure the one you want to edit is the one AutoCAD is focused on?
Are you working on dual monitors?
Is your commandline docked? if not, and you dock it, does the problem go away?
Was a fix determined for this? I am having this issue also on AutoCAD 2019, all of the above suggestions have not solved.
pendean
Community Legend
Community Legend
@Anonymous Do you have the 2019.1.2 update installed? IT is required.
