Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
COMBINE XREF IN ONE FILE
joanne_velasquez
joanne_velasquez
Community Visitor
Community Visitor
I have several xref drawings I want to combine. I edited some of them per file/ change layer properties, but once I xref to new file to combine (for sending) I have to redo all changes on the properties thru the (vp) layer settings per paper space layout. Is there a much faster way to do this?
ennujozlagam
save to another file and bind the xrefs before sending?
3wood
You can use Layer States Manager to Export the layer settings as a *.las file, then Import it in the new master file.
Valentin_CAD
@joanne_velasquez ,
Look into the VISRETAIN variable:
This video may provide an understanding:
  • Power of the Triad—Effectively Manage Xref and Xref Layer Property Overrides in AutoCAD (VIDEO)
Also, consider using the eTRANSMIT command when sending files:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
