Colors not displaying in the drawing properly
Luke_Y.AGII
Message 1 of 12
Luke_Y.AGII
See attached vid.
Everything is grey or white and not showing the color by layer.
Objects are 3D solids, not blocks
Object properties are colored "by Layer"
I am in model space
PAGESETUP: Plot stye table = none, Display plot styles box is unchecked
PROPERTIES: Plot style tabe = none, Plot Style =by color
any guesses?
Replies (11)
Message 2 of 12
Luke_Y.AGII
I created a test layer and was able to draw a magenta rectangle
changing the layer color changes the rectangle, but changing the color of the other layers doesnt change them. (but the outline color when hovering over [selection] DOES change)
EDIT: It appears that making new layers and transfering objects to these new layers lets them display the layer color. so that is a work around, but id like to understand what is going on.
Message 3 of 12
TheCADnoob
Are materials applied?
CADnoob
Message 4 of 12
Luke_Y.AGII
not as a far as I know. there's no mention of materials in the PROPERTIES
Message 5 of 12
TheCADnoob
do a match properties with your magenta rectangle and see if the colors change.
CADnoob
Message 6 of 12
Luke_Y.AGII
Yes, this is equivalent to moving them to a new layer, which we have already discovered is a work around.
Message 7 of 12
TheCADnoob
ok, compare what changes in the properties palette before and after you do a match properties.
CADnoob
Message 8 of 12
Luke_Y.AGII
 BEFORE
 AFTER
Message 9 of 12
TheCADnoob
any change you can provide a sample file?
CADnoob
Message 10 of 12
Luke_Y.AGII
Unfortanely, i am not permitted to post actual work files. ive just used the workaround to get everything displayed how I would like, i guess the WHY of it is going to have to remain a mystery
Message 11 of 12
TheCADnoob
I understand.
Have you tried changing visual styles to see if that makes a difference?
CADnoob
Message 12 of 12
Luke_Y.AGII
no, I just moved everything to new layers and gave up on trying to find out what it was.
