Color Plotting
Color Plotting
RJK42
Message 1 of 22
Color Plotting
RJK42
I have been using the plot style table set to "monochrome.ctb" and usually have no issues when it comes to plotting in black and white.  Now, no matter what I do, I am printing in color.  All layers are set to black in set up.  I have not changed anyting and I compared the settings to a previous project and its all the same.
Replies (21)
Message 2 of 22
Just a thought....do you have plot with plot styles checked in your plot dialogue box? Just a question.
Message 3 of 22
Patchy
If you used true colors, monochrome will print colors.
Message 4 of 22
RJK42
I tried it checked and uncheck.  Both is printing in color.
Message 5 of 22
RJK42
I haven't been using true colors
Message 6 of 22
Patchy
What about Shade plot ?
Message 7 of 22
RJK42
shade plot is shaded out.  I can't change it. It shows "As displayed"
Message 8 of 22
Patchy
Go through each viewpport and change Visual style.
One or more viewports is set to print differently.
Message 9 of 22
RJK42
I tried setting all the viewports to 2D Wireframe and still print in color.  I opened up a previous project and compared the settings and they both match but I can print correctly on the previous but not the current.
As for the 2D wireframe, I need to print in hidden, but it's not working anyway.  I emailed the company where I purchased the software and subscription.
I'll post the solution when I receive it.
Thanks for the help!!
Message 10 of 22
Patchy
Very interesting problem, can you post this drawing with only a few lines in it? Let's see.
Message 11 of 22
Dan.Scales
If you have the Shade plot setting as Hidden for the Viewports then the plotstyle will not be used and the drawing will plot in colour.
If you can upload an example drawing we should be able to say exactly what the cause of the issue is.
Dan
Dan Scales
Message 12 of 22
RJK42
I clicked on the viewport and under properties, shade plot was set to hidden.  I changed that to "As Displayed".  I right clicked the layout and went to "Page Setup Manager" select "Modify", and confirmed that under "Shaded viewport optios" - "Shade plot" is set to "As displayed".  Still prints in color.
I compared this to other drawings and everything is set the same.  For some reason, its not changing.
I have support from Synergis working on the issue.  Still can't figure this out.
Message 13 of 22
very interesting problem, I also am interested in knowing the solution, when you have
Message 14 of 22
Alfred.NESWADBA
if nothing like _AUDIT or _RECOVER helps, upload a drawing that does show that problem.
You can delete the elements from modelspace and titleblock if there is something not for www-publication, but leave some entities so we can see and reproduce the issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 15 of 22
RJK42
I received tech support regarding the plotting in color issue.  I apologize for the wait but I wanted to see what they had to say first.  Their solution was to configure the plotter settings.
Right click the ploter,
Printer Properties,
Under the "General" Tab,
Preferences,
"Layout" tab,
"Advanced" button,
Under Graphics
-Image Color Management
then adjust the ICM Method and ICM Intent (see attachments):
Then go back to click the "Paper Quality" tab
and set the color to Black and White.
Then they suggested to create pc3's specfically set to only Black and with along with all the settings stated above.
If I set the ctb file to plot all layers to Black, I shouldn't have to go through all this.
I still think the issue has not been solve so I attached the DWG.  I had to trim it down so I can upload it.  If anyone can find the solution please post it.
Message 16 of 22
RJK42
Images for the ICM method and Intent
Message 17 of 22
Alfred.NESWADBA
you have set your viewport to be plotted with visual style "realistic" ==> that renders ==> and rendered output creates true color ==> and true color can't be converted by CTB or STB settings.
Change either the visual style within the viewport or the shading-plotstyle for the viewport it to "old hidden" (don't know the excat word) and that's it.
Therefor open the property-window (<Ctrl>-<1>) and select the viewport.
- alfred -
Alfred NESWADBA
Message 18 of 22
RJK42
I tried to set it all to hidden or 2d wireframe and still I get color when I print it out.  Not sure if there is a bug, but have you tried it on your end??
Message 19 of 22
Alfred.NESWADBA
where did you set it? And don't use "hidden", but instead use "old hidden" (or "legacy hidden" or whatever it's name is)
I did, of course 😉 Find the attached files and look into it.
- alfred -
Alfred NESWADBA
Message 20 of 22
Dan.Scales
You do not need need to the plotter/printer to plot in black.
The solution posted by Alfred is the correct one.
Dan
Dan Scales
