I am trying to match the color in the text Island temp.... and also the font. Can't seem to find a font that matches in Autocadlt 2014. Also the color of the text is something I need to match. I have tried color 178 and 0,2,86. Any help would be appreciated.
AJ
AJ
Solved by hosford. Go to Solution.
if you use microsoft paint, select the color you want to match with the eye dropper, then edit the color.
see attached image
see attached image
As far as font, Acad can use most TrueType fonts -- can you contact the logo creator and ask them what they used?
