I have a block with multiple blocks in it.
Each individual block has the color set to by block.
In one case I need the all of the block to be the same color (Magenta).
Other cases I need each individual block in the to be a different color. (Cyan and Yellow)
Is there a way to achieve this with out exploding?
Beth
Solved by pendean. Go to Solution.
AFAIK a block has only ONE color property. So all inner blocks with "byblock" color property inherit outer color. Either from layer, if it's "bylayer", or object's property.
[I don't think that can cover the "In one case ... Other cases ..." consideration in Message 1.]
