Closed Polyline does not show area in field
Message 1 of 13
Hi everyone,
I tried to join all to polyline, it doesn't show are in the field. But it works with command 'aa'.
I think the problem is there are some gaps or overlap lines. Although I checked it.
Do you know any solution to find the gap and the overlap line then  fix it quickly ? I often stuck by this error.
Replies (12)
Message 2 of 13
imadHabash
it should be like below image !! we need to take a look to your CAD dwg itself to get a useful help , would you please attache it here? you may need to explode your polyline then create another one by BPOLY command.
Imad Habash
Message 3 of 13
rkmcswain
Message 4 of 13
vinodkl
I assume the polyline is self-intersecting and that's why the area is not shown. Try to explode the polyline and then use the command "OVERKILL" to remove overlapping objects and then use the command "PEDIT" or "JOIN" to join it into one polyline. You could also use the command "BOUNDARY" to create a boundary of the polyline had then use that polyline to display the area field.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 13
Here is my file. Please check it.
Message 6 of 13
I tried to test as that way but it did not work.
Message 7 of 13
imadHabash
click on below image to see how it's work fine !! i did not do any changes . I've just open it and do what the below image display .
Imad Habash
Message 8 of 13
Thank you, vinodkl! It worked.
But do you know any lisp or the other solution to solve this problem automated or quickly? Because I have to fix many objects at the same time.111.PNG
Message 9 of 13
Thank you, imadHabash! I use the solution in the above comment and it works.
I think the problem is how we fix the gaps and overlapping lines to create the closed polyline.
Message 10 of 13
imadHabash
be careful !! in your image the area ( 73748.4 ) is different and not match the CAD file that you attached previously and from your images in first original post .
Imad Habash
Message 11 of 13
I got the last area with the yellow line. Therefore, it brings a different value.
Message 12 of 13
What is your AutoCAD version? It works on CAD 15 (I have just tested with my friend) but CAD 13 doesn't work or by the error during setup.
-----for Autocad 15------
-----for Autocad 13------ 
Message 13 of 13
imadHabash
tested on AutoCAD 2017 .
Imad Habash
