Closed polygons using sketch tool
heloisamuzzi
Message 1 of 8
heloisamuzzi
Community Visitor
Community Visitor
Hello!
I only recently discovered the "SKETCH" tool to draw freehand polylines, however I'd like to be able to close these polylines, forming polygons at the end. So far I've been closing them with the "CHAMFER" tool, the fastest solution I found. For context, I am drawing a decal of an image, and it would really help me to know if there is a fast way to draw freehand polygons with minimum clicks.
Replies (7)
Message 2 of 8
Patchy
Try polyline edit, when they are polyline, select all of them and use Property Pallet, use Closed, choose YES.
Message 3 of 8
pendean
Community Legend
Community Legend
SKETCH command does not have that ability: you could try using PEDIT command's CLOSE function after creation, quicker that CHAMFER or FILLET, if you like the results. Then you can automate that with a LISP, and address all the other Sketch settings in there too like
Message 4 of 8
j.palmeL29YX
Jürgen Palme
Message 5 of 8
Patchy
Cool, my dinosaur Autocad gave me no options for line, polyline......
Message 6 of 8
Kent1Cooper
@Patchy wrote:
... no options for line, polyline......
That's the SKPOLY System Variable.
Kent Cooper, AIA
Message 7 of 8
j.palmeL29YX
@Patchy
Das muß aber eine sehr dino-ige Version sein. Das von Dir Gezeigte kenne ich nur in den Versionen bis 2010. Bereits ab ACAD 2011 zeigt der Skizze-Befehl die obigen Optionen.  😉
[edited]
Jürgen Palme
Message 8 of 8
Patchy
