clipping block not correctly
binuntachari
Message 1 of 8
binuntachari
I clipped a block & some areas are showing like this. if any one have solution please help me about this.
Replies (7)
Message 2 of 8
imadHabash
Would you please share with us your case as a CAD dwg file for testing?
Imad Habash
Message 3 of 8
binuntachari
this happening every time when you clip block, some areas have like this.
Message 4 of 8
j.palmeL29YX
Your geometry resides very far away from the origin. Try to move the geometry (temporarily) close to the origin 0,0,0 (and renew the clipping) and let us know iif that helps.
Jürgen Palme
Message 5 of 8
imadHabash
I suggest to move your object near to 0,0,0 . any changes?
Imad Habash
Message 6 of 8
Simon_Weel
Opened the drawing in AutoCAD 2024 and don't see any quirks...
Message 7 of 8
j.palmeL29YX
@Simon_Weel wrote:
... don't see any quirks...
(view in My Videos)
But - after(for testing) moving all the clipping polylines close to the origin and creating the clippings new all defects are gone. Also after moving the clipped blocks back to their initial position no problems here.
Jürgen Palme
Message 8 of 8
Simon_Weel
Ok, after watching the video, I do see them quirky tiles. Seen that before when using SOLID as hatch pattern. Since solids don't print very nice to PDF, we use a dense line pattern hatch to get a good looking PDF. I guess when using that trick in this drawing, it will make it significantly slower as it already is....
