Click on text and zoom on a bloc
I would like found a solution just for click on a text : for example on that switch, I want to click on N101 and zoom on that other end 🙂
Thank You
Jeremy
Alfred.NESWADBA
Without development? Could be done with hyperlinks pointing to named view (and having defined a named view on the other end), lot of work.
I would think about a tool doing this, dependent if you have some knowledge with AutoCAD's API's (or some guys knowing a bit about this).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
s.borello
Just use your mouse wheel.
