Classic view
Classic view
Message 1 of 9
Classic view
Does AutoCAD 2017 allow you to change over to classic view?
Replies (8)
Message 2 of 9
Mark.Lancaster
@Anonymous
First thing you are in the incorrect forum.  This forum is solely used for installation and licensing issues of Autodesk products.  This type of question should be posted over in the AutoCAD Forum.
But to answer your question..  You can but its a manual process.   My suggestion..  Stop hanging onto legacy viewing configuration..  Smiley Very Happy
Mark Lancaster
Message 3 of 9
natasha.l
Hello @Anonymous,
Sure, you can easily make this change and recreate the AutoCAD Classic workspace by following the steps below:
  1. To display the menu, click Quick Access Toolbar drop-down > Show Menu Bar.
  2. To hide the ribbon, click Tools menu > Palettes > Ribbon.
  3. To display the toolbars you require:
    1. Click Tools menu > Toolbars and select the required toolbar.
    2. Repeat until all required toolbars are visible.
  4. To save the workspace:
    1. Click Tools menu > Workspaces > Save Current As.
    2. In the Save Workspace dialog box, in the Name box, type AutoCAD Classic.
    3. Click Save.
Let us know how it goes, I moved this post for you to the AutoCAD forum. Thank you.
Message 4 of 9
john.vellek
Hi @Anonymous,
As much as I like to encourage users to adopt the newer interface since it has been around for so long already, I do have this list that should get you to a "Classic" type appearance fairly quickly.
MENUBAR = 1
Tools > toolbars > acad > layers
hoover over layers toolbar > right click > properties
hoover over any toolbar > right click > standard
hoover over any toolbar > right click > styles
hoover over any toolbar > right click > workspaces
RIBBONCLOSE
arrange toolbars
workspace, saveas, Classic
John Vellek
Message 5 of 9
natasha.l
Hello @Anonymous,
Have you made the change to Classic View?
Please let us know if you have any more questions. If a reply has helped resolved the issue or answered your question, please "Accept As Solution" to help others in the community.
Thank you.
Message 6 of 9
I read that since AutoCAD for MAC never had the classic view I cannot change the new view to classic view in AutoCAD 2017 for MAC.
Message 7 of 9
natasha.l
Hello @Anonymous,
Sorry to hear that you will not be able to make the change because it is not available on a Mac operating system. I just wanted to let you know that there is a Mac-specific forum for AutoCAD in case you have any further questions in the future. http://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
Thank you for reporting back with an update. Smiley Happy
Message 8 of 9
giles5
Community Visitor
Community Visitor
A very unhelpful 'suggestion', Mark....... people have different genuine reasons for needing such things. When they come to a proper source for help, it reflects extremely poorly when they are met with sarcasm.
@giles5 - this post has been edited due to Community Rules & Etiquette violation.
Message 9 of 9
manieshkumar.suresh
  • Drag and drop method:
    1. Enter the CUI command to open the Customize User Interface window.
    2. Select a workspace or create one.
    3. Click the plus symbol to open the Toolbars tree on the left side.
    4. Drag the desired toolbars to the Toolbars tree on the right side.
    5. Click Apply and then OK to close the configuration editor.
Note: To learn more, watch this Screencast: Toolbars and Workspaces in AutoCAD 2015.
  • Customize Workspace method:
    2. Select a workspace or create one in the Customizations in All Files pane on the left.
    3. Click the Customize Workspace button in the Workspace Contents pane on the right.
    4. Click the plus symbol next to Toolbars in the tree on the left.
    5. In the list under Toolbars, check the box next to toolbars to add them to the selected workspace. They will be shown under Toolbars on the right (see below).
    6. Click Done on the right.
    7. Click Apply and then OK to close the configuration editor.  Classic_Workspace_Script.zip
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
