Check for overlapping hatches
I am working with hatches and I would like to check in a drawing if an hatch is overlapping another.
I have tried the overkill command, but although two hatches may have overlapping areas, the respective lines might not be, and the command becomes useless.
Is there any way to check for this problem? Some command I am not aware of? Or do I have to program in VBA/autolisp?
Replies (15)
JBBs
You can set the hatch origin points to be coincident, so the lines do overlap.
Overkill still won't get rid of them, though.
Thanks for the reply, but I never want them to coincide, I just want to check in the end of the drawing if there's some overlapping between hatches (and then eliminate them).
ВeekeeCZ
If just visual control would be enough you can set all hatches to solid with transparency up to 50%.
IMHO any programming solution would be challenging. Have you thought of a method to use?
pendean
Community Legend
Community Legend
change transparency or colors then look for visual cues for overlaps.
vladimir_michl
You can use the HatchOverlap freeware utility to detect hatch overlap areas - see https://www.cadforum.cz/cadforum_en/hatchoverlap-check-for-any-overlapping-hatches-in-a-dwg-tip12429
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
s.borello
I don't think there is a one click solution for you... you will have to use your eyes.
Peter2_1
Hi Vladimir
I tried your tool with Map 3D 2023 german and got this result:
Punkt liegt direkt auf einem Objekt.
Konnte keine gültige Schraffurumgrenzung finden.
Fehler: Automatisierungsfehler Objekt wurde gelöscht
Befehl:
Any idea for a problem?
AutoCAD Map 3D 2023 German / Oracle
vladimir_michl
Can you please send me the complaining drawing? Ideally just the simplified part of it which is reporting the problem.
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Peter2_1
Hi Vladimir
here it is. I don't know the element in detail, but it is reduced to 19 elements where is brings the error.
vladimir_michl
? what is "here" ?
-vm
Peter2_1
Sorry - attached it now in the post above ..
vladimir_michl
Thanks. I have looked at it, done a small update (V1.1) which could help in some cases but this approach will never be fully universal - in some cases (center point on a border) it will always fail.
Peter2_1
Thanks, Vladimir.
I'm surprised by the really quick solution.
I just downloaded the new version - to I understand it right that the problem reported before it one of the still failing ones?
BTW: For the next update I want to suggest another handling of the "undo-behaviour". Now there are maaaany single steps in "undo" - alone 7 steps for 2 hatches.
vladimir_michl
There is now a better version (V1.2) with error handling and Undo.
https://www.cadforum.cz/en/download.asp?file=HatchOverlap
Peter2_1
Hi Vladimir
thanks - the undo and the error-management is clearly improved.
But what I don't understand - when does it marks "overlaps"? The attached drawing contains two polylines - when I add hatches, the smaller one is marked as overlapping, but IMHO they are exactly "touching", not overlapping. Does it depend on some settings, some tolerances?
