Changing text size by scale in model space
mosness
mosness
Is there a way to have all the stand alone text and leader text change when changing scales in model space.   I have my textstyle set to standard and the height set at 0.   In my dimension settings I have the text set to standard also.   For example when I change from 1/4" scale to 1/8" scale, the dimensions change just fine, but none of the stand alone text or the leader text changes.  I have to select all that text manually and in the properties change the height to the new scale text height.   Can anyone help me with this?
pendean
Community Legend
Community Legend
Annotative text: doesn't look like you use that feature. Explained in HELP, explore it.
Here are some web documents to help you get started:
https://www.google.com/webhp?tab=ww&ei=2SXaVN7pJo38yQSMq4LIAw&ved=0CAsQ1S4#q=how+to+use+autocad+anno...
