I've got a general drawing template set up for pdf printing sheets into 1"50 scale @ A3. Inside the template I've set the lineweights to 0.18mm. I've tried using a lineweight of 0.00, but I get some clashing on either pdf prints or digital pdf viewing due to pixelation etc.
I'm printing a very large area drawing, approximately 500mX500m and wanted to print 68 sheets of 1:250 and then have a large not to scale general arrangement drawing on the back sheet. Because I've got the lineweights set-up as 0.18mm, when I look at the GA sheet the lines bleed all over each other. I've googles changing lineweights in the pagesetup, but I can't seem to get anything to change on the plotted drawings. I upped the lineweight scaling to 1:2000, but it looks about the same as if I hadn't changed the output plotting.
What I wanted to be able to do was change the lineweights to 0.00 in the GA sheet, but I'm thinking now this might not be possible.
