Autocad text overlapping after copy and paste from different files
weimingpoh
Observer Observer
weimingpoh
Observer
Observer
The text fonts overlap each other after i copy paste my title block from another file. See attached. photo_2021-06-28_13-18-28.jpg
S.Faris
This could be because of the same Text style names in both drawings with different property values.
The easiest solution could be to rename the text style using RENAME command before copying. This should avoid the conflict.
SALMANUL FARIS
weimingpoh
Observer
Observer
Tried your solution but it did not work for me.
S.Faris
What are the text style names in Source drawing and Target Drawing?
SALMANUL FARIS
weimingpoh
Observer
Observer
The text style name in source drawing is Arial_22 and when i copy paste into target drawing, it changes to Arial_13. When i change it to Arial_22 in the target drawing it doesn't fix it too
S.Faris
Try purging the destination drawing before pasting. Just to make sure, could you rename the text style used in source drawing to something random like "test123" and then paste it into the destination drawing.
if all fails please WBLOCK the text from source and destination files into 2 different files and post it here.
SALMANUL FARIS
vinodkl
Hi @weimingpoh
If I am not wrong, then you are using AutoCAD 2018. This is a known issue in AutoCAD 2018. The text crumbles as you have shown in the screenshot when the "Arial" font is used. This will not affect the PDF output and it would look fine in the PDF. You can correct this issue by updating to the latest update available or change the font of these text from "Arial" to "Arial baltic" 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
